W124 wiring loom DIY?
Discussion in 'Engine' started by Williamwoo, Oct 6, 2010.
  1. Williamwoo
    Williamwoo Hardcore MB Enthusiast
    420
    Jul 8, 2010
    Somerset
    Car:
    W124 E320 estate / W212 E350 Brabus D6 estate / Panda 4x4
    Hi all,
    Well the inevitable has happened and my wiring loom is kaput. I am aware that a new one is about £600 so, as I have some time but not much money, I was contemplating having a go at fixing it myself.
    I'm no electrician but I'm reasonably competent with a soldering iron and I'm wondering just how hard it is. Clearly, the biggest problem would seem to be the various sealed connectors, which I believe you cannot buy on their own. Is it simply a case of cutting them open as neatly as possible, soldering in the new wires and then resealing them (glue?)? Are there any connectors that are really tricky?Are any types of wire more suitable than any other? What sort of glue should I use? What sort of casing should I put round my lovely new bunches of wire? Any other issues?
    Or should I just start saving for a proper one?!
    Any suggestions gratefully received, many thanks.
    Yours perhaps naively,
    Simon
  2. d w124
    d w124 Hardcore MB Enthusiast
    12,110
    Dec 30, 2008
    london
    Car:
    w124 3.6AMG styling E320 S124 Lorinser styling
    Hi there Simon,this was posted the other day by Nick Froome
    The first part to fail is normally the loom from the ECU to the coil packs. The "valley" between the cams is a pretty hot place and the loom degrades and shorts out, eventually killing the output transistors of the ECU
    MB make a loom replacement section for £7 and you'll need three for an M104 engine. The tails are long (2 metres approx) so you should have enough length to go back to the ECU. Alternatively you can join into the loom on the section between the engine & ECU
    The replacement sections comprise a plug & two-core cable - which looks suspiciously like mains cable as it is a brown & blue twin-core cable in a black sheath
    Nick Froome
    Have a look at this thread http://www.mbclub.co.uk/forums/engine/67830-w124-engine-bay-wiring-looms.html?highlight=w124+loom
  3. mattc
    mattc Hardcore MB Enthusiast
    2,425
    Sep 27, 2007
    Midlands
    Car:
    2003 E270 avantgarde, 1994 E320 Coupe
    When you crack the loom open you will find plastic sheathing detaching itself from the wires throughout its length. Of course given enough time you can re make the loom but are you confident you will mirror everything exactly? You could, I guess, do a section at a time over a few hours.
    I have my old one in the garage from when it was replaced with a brand new one. I intend to renew it but even if I do will I have the confidence to attach it to the car and try it...I do wonder.
    ultimately is it worth your time against the money? Replacing it now will probably mean for the rest of the cars life you now it will not be a source of problems.
  4. scillyisles1
    scillyisles1 Hardcore MB Enthusiast
    157
    May 1, 2010
    A new loom (with all the right connectors) is just over £400 why would you want to try to repair an old loom bit by bit with all the risks this involves. Get in wrong and you will fry the ECU which costs a lot more than £400.
  5. OP
    OP
    Williamwoo
    420
    Jul 8, 2010
    Somerset
    Car:
    Thanks for the replies.
    Nick, I fear that simply replacing the bit that sits in the 'cam valley' won't really help as I can see considerable disintegration of individual wire insulation in at least 3 other places.
    Scillyisles1, where can you get a new loom for £400?
    Cheers,
    Simon
  6. ched999uk
    ched999uk Hardcore MB Enthusiast
    135
    Sep 4, 2010
    Sunny Blackpool
    Car:
    C230K 1.8 Coupe Evo Pano
    One thing to remember is that solder is strong but brittle. So although soldering in new sections of cable will work it might not work indefinitely. As the joints flex and vibrate with engine movement and heat you may find after a year or so you start to get weird issues that are caused by solder fractures.
    Its usually best to use some sort of mechanically crimped connectors.
    If you do want to solder you can buy self adhesive heat shrink tubing. It just slides over the cable before you solder. Once you have soldered and it has cooled then slide the tubing over the joint and heat upi with the tip of your soldering iron usually works. This shrinks the tubing and activates the adhesive thus sealing out moisture. The tubing also helps make the joint a bit stronger.
    Good luck with what ever you decide. You could just replace a single cable at a time, that way you don't get anything wrong. It may be time consuming but you will get it right.
    1 person likes this.
  7. Druk
    Druk Administrator Staff Member
    5,076
    May 28, 2004
    Not far from Edinburgh.
    Car:
    2011 S212 E350CDi. 1981 R107 300TurboDiesel.
    I wondered that too?
    Simon. A few years ago I made a 320TE W124 loom using the duff ones from my car and one from an R129 I was kindly donated. The donor wires came from a complete and unused 124 main loom bought from BlueStarBill on ebay for £15.00. It came complete with miles of tube sleeving which I carefully cut and re-used. My rot went all the way back to the ECU plug. I'll post some pics up when I get them sorted but is was a fairly easy task if taken steadily one wire at a time. I made several diagrams and took pics of everything as I went along and noted pin numbers and colours. There are several cables in the loom made from co-axial wire with sealed plug ends and they were unaffected by the rot so were re-used. The biggest prob is opening some of the sealed plugs to get at the pins.
    The main ECU plug with the top cut off. For those who think the rot stops at the coil section. :eek:
    [​IMG]
    The plug for the MAF
    [​IMG]
    And opened up.
    [​IMG]
    The main culprit. This is the plug to one of the HT coils. When you switch on the ignition the big pink/red is instantly live. When the insulation breaks down and it touches the trigger black/yellow....pop goes the ECU.
    [​IMG]
    [​IMG]
    Two looms. The old at the rear and the new taking shape with it's new plastic casing.
    [​IMG]
    Sections for the coil packs made from heatproof cable (Maplins) with fire resistant sheathing.
    [​IMG]
    The rewired Maf plug with reclaimed sheathing and tiewrap securing before the top is glued back on.
    [​IMG]
    7 people like this.
  8. scillyisles1
    157
    May 1, 2010
    If you know the part number for the wiring loom then you can type the part number into the Inchcape Mercedes Benz parts on-line system.
    I did that recently for my 1996 E320 Cabriolet which has A/c. 5 speed gearbox etc and the price quoted was just over £400 inc VAT.
  9. Druk
    5,076
    May 28, 2004
    Car:
    Fair enough if that is what they're selling it for. But I ordered a small part for a 107 flagged as costing £1.00 and they emailed back saying it wasn't stocked and if I wanted one ordered it would now cost £13.00. (and the colour they said was available now wasn't').
    I'm not saying making a DIY loom is for everyone, but I'm no electronics guru...just slightly handy with a solder iron and a pen and paper. It's actually not that difficult once you get started.
  10. neilrr
    neilrr Hardcore MB Enthusiast
    5,915
    Jul 20, 2004
    Car:
    Various.
    Didn't someone (Andy k IIRC) have some kind of deal with his local dealer for discounted OEM W124 looms?
  11. d w124
    12,110
    Dec 30, 2008
    london
    Car:
  12. neilrr
    5,915
    Jul 20, 2004
    Car:
    Various.
    Thanks, I couldn't find that thread.
  13. scillyisles1
    157
    May 1, 2010
    I suppose that is a possibility but I have been buying a lot of parts recently and before ordering from the dealer, I check the parts price online at Inchcape Mercedes Benz parts site. In every occasion they have been spot on in terms of price. The parts I have been ordering are not your run of the mill parts either - all parts have been special order with many having to come from Germany.
  14. OP
    OP
    Williamwoo
    420
    Jul 8, 2010
    Somerset
    Car:
    Thanks for your various comments, expecially Druk for the photos.
    Ok, I've got the old loom out and things are not actually too bad apart from near the engine. The MAF lead looks very similar to yours Druk and the insulation is almost powder-like for the first foot or so. However, from there, it is fine and indeed all the wires by the time they get to the main ECU plug show no signs of any cracking. Is it wrong to assume therefore that it is solely because of the heat that the insulation disintegration (I quite like that phrase!) occurs? In other words, my plan is to simply replace all sections that are bad but joining them in near the ECU plug but not in the actual ECU plug itself as I feel I'm more likely to do more harm than good if I mess around with the latter. Incidentally, my ECU plug looks very different to yours, Druk - could it be because mine is a slightly newer E320 as opposed to 320TE?
  15. w124nut
    w124nut Hardcore MB Enthusiast
    543
    May 9, 2004
    Somerset
    Car:
    Mercedes W124 E320 cabriolet
    If I remember correctly, In early 2006 I sent to Derek in Bathgate (Druk?) the old wiring loom from my 1994 W124 E320 cabriolet as he said that he is going to make up a new loom. If Druk is Derek then perhaps that loom he refers to came from my W124 E320 and not a W129.
    The new engine wiring harness in 2006 cost me £496.33 from MB Exeter and I asked for a total replacement even though the garage recommended a part replacement.
    It is nice to know that old parts of cars are being recycled.
  16. grober
    grober Hardcore MB Enthusiast
    22,296
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    I am all in favour of repairing things if possible:thumb: but remember when you come to sell the car that an official invoice for a replacement loom would be a strong selling point for knowledgeable buyers. ;) DIY loom repairs can vary from better than factory spec to liable to fail again at any minute! :eek:And buyers do tend to assume the worst case scenario. :doh: The best way to proceed is perhaps to consider how much longer you are going to keep the car and what fraction of the total value of the car a new loom might be.:dk:
    At least labour costs are not a problem as total replacement is a relatively easy DIY.
  17. OP
    OP
    Williamwoo
    420
    Jul 8, 2010
    Somerset
    Car:
    Hi again all,
    Ok, I'm about to start replacing all bad wires. Is there any particular type I should use? I have quite a lot of Maplin's 24/.02mm, 45mm pvc sheath - is this suitable? Druk - I notice from your many helpful photos that you've replaced like with like colour-wise. Where can I get such a variety of coloured wire from (Maplin's only do 6 colours)?
    Cheers,
    Simon
  18. grober
    22,296
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    the size of the cable required for any purpose is dependant on the cross section of the conductor material . This depends on
    1. the current carried.
    2 voltage drop permitted= depends on cable run length
    3. whether the cable is run with others= heat dissipation
    Cable size is expressed by no of strands of wire and their cross section
    e.g. 14/0.25 =14 strands of wire each 0.25mm gives a rating of 6amp and a voltage drop of 0.02715 V/m/A
    You can do a visual check on the old wire to get a suitably rated replacement.
    Insulation [ material and thickness] is not normally a problem at 12V but any cable should have stated operating voltage and an operating temperature for insulation breakdown.
  19. Druk
    5,076
    May 28, 2004
    Car:
    Simon.
    For my multi-coloured wires I used an interior loom from a W124. This I bought from Ebay and stripped it down. You could get similar from a scrapyard I suspect although with quite a bit of work. The good thing about an OEM loom is the plastic sheathing it comes encased in. The wires pull out and the sheathing gets re-used as well. See pics. The 129 loom I referred to was also sent to me by a kind donor and it proved extremely useful if only for the coilpack plugs which on a 129 are dismantleable. The ones from a 124 are sealed. How inexplicable and awkward is this?
    The wires I used for the new leads into the coils is Maplin heatproof sheathed in braided heat proof stuff. The large wires are the feed which (on my car) comes from a JB on the N/S inner wing and is live with ignition. These can be joined either inside the cover which makes for a small diam loom coming through the neck or outside as I did. Either way they are common so you could even loop them between coils. The three smaller dia wires are the pulse trigger wires from the ECU.
  20. grober
    22,296
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    Safest to use internal wiring from a pre facelift [ easy to identify] W124 to avoid the dodgy insulation issue. Best to avoid the harsh environment of engine compartment wiring too if possible. At the right price should be considerably cheaper than buying new cable drums copper is expensive nowadays!
Share This Page
