Jason 2106
- Jan 12, 2017
- ml 270
I have just started having a few faults with my ML . Namely it beeps at me as soon as you turn ignition on . About 10 to 13 times and the handbrake light is on all the time ...when you try and drive it's in limp mode 2nd and reverse only and you get a constant warning beep until you stop.... now hearing battery voltage can cause all sorts of gremlins I checked it only to find the alternator was chucking nearly 16 volts into it....
So my main question is i have the type of alt with the connectors on front by the pulley can I use the other type with connector on rear as a straight swap???
Also my other problems ....any opinions.
