pompeypetey
I appreciate diagnosing these kinds of things is very difficult over the internet, but I'm wondering if anyone has any bright ideas before I give up on the infernal thing.
Around 7 months ago head gasket failure was diagnosed due to over pressurisation of the cooling system causing coolant to spill out of the expansion tank and the top radiator hose to collapse when left to cool down. CO2 was also detected in the coolant and the system pressurised from cold in around 30 seconds.
The expansion tank cap was replaced, then the expansion tank along with another new cap to no avail.
At this point I bit the bullet and spent the next 6 months replacing the head gaskets, valve gaskets etc. New TTY bolts used throughout. I knew this was a risk because everyone was telling me "no way is it the head gaskets on that engine" but hindsight is a wonderful thing and perhaps I should have listened! Unfortunately the same people were not offering any alternatives.
Both heads and block were cleaned and checked with a level, so not warped.
Anyway... Engine is back together and £1000 ish later it is doing the same thing
I am now of a mind to simply drive it to the nearest breakers yard and give them the keys. Before I do I am hoping that someone here can suggest something I may have missed.
This car has been the biggest lemon I've bought and I've owned close to 50 cars, but I'd still like to save it if it makes any kind of economic sense to do so. It's a fundamentally solid car with only 70,000 miles and I quite like it.
New engine is a possible I guess, but may just be another can of worms.
