W164 2007 FM Aerial Wiring
Discussion in 'Electronics' started by Badvgood, May 11, 2017.
  1. Badvgood
    Badvgood Member
    31
    Mar 11, 2017
    Car:
    ML63
    2007 W164 FM aerial questions
    I am trying to fully understand the diversity aerial set up and booster arrangement on this model and need some help from anyone that has been here before.
    At the head unit end, my car has three Fakra connectors. Bright yellow, black and blue.
    Blue is for GPS I believe
    Black is for FM I believe
    Bright yellow – Diversity aerial?
    Moving to the rear, in the roof panel there is a small box with three Fakra connectors going to it.
    Blue, Black and Green. What is each one for?
    There is also two other connector. One red/pink with a single wire and another black connector with three wires. Black, red and yellow.
    What are these for?
    Moving to the tailgate, there is what I think is a aerial booster. It connects to the rear heated screen with two wires.
    It also has a blue Farkra connector and the same red/pink single wire connecter as the one in the roof panel has.
    Its gets it’s earth from the tailgate it is bolted to.
    The rear ¼ side glasses also seem to have a aerial in them. What is this used for?
    My overall aim is to get my aftermarket head unit to have a great FM signal which is does not have at the moment.
    Hopefully using the diversity aerial system which I think will be the tailgate glass aerial and the one in the roof panel.
    Any assistance would be great.
Share This Page
