Currently have engine check warning light on and suggestion is clogged DPF, dealer stating the unit is Regenning too often and they want to remove DPF and inspect engine and report back to MB as they haven't seen this before?
Any suggestions on what might be the cause / solution. Also potential cost?
ML 350 - 70K, 61plate.
It was in with DPF fault last month. cleaned and new oil?
Alternatively are there any good independent garages around south Yorkshire that any one can recommend to look at this?
