Hello
Please could you give me some advice on the following fault:
Rear wiper only moves in 90 degrees "steps" when set on intermittent. When on wash/wipe mode seems to behave normally.
Visual check of motor looks Ok. I have cleaned all electrical connections to motor and relay.
Attached photo of relay which is obviously not original!
Is the problem with the relay and it is just a case of replacement or should I check other parts of the circuit?
Many thanks
Many thanks
