I have a W168 A170 with Electric Windows that have started opening by themselves.
Three of the four are now doing this every time I start the car with the exception of the drivers window. There are no OBD codes showing on the car. I have a two minute battle with the windows to get them back up and then the car gives up and they remain up for the rest of the journey. As soon as I turn the car off and on the battle starts again. I have completed the window reset procedure on each window but this has made no difference. I did have a low battery and replaced this, again re-setting the windows after the battery change but it made no difference. Finally if I select the child lock feature it drops the front passenger window.
Whilst its cold I have resorted to removing the two 30 amp fuses, does anyone have any suggestions? Thank you for your help in advance. David
