I have a couple of question, I can't find an answer to:
1. Is the the airbag key for W169 a T30? Part A1265890010
I'm too tight to pay over £15 to MB to get a torx screw bit
Also, it looks about 80mm in length? Will 100mm one be OK, or is it too long - I have no aft/fore adjustment, so might end up not having enough space; on the other hand, 75mm bits look too short ...
2. Does the airbag need to be unplugged, to remove the button controls assembly?
Also, do I have to disconnect the negative terminal on the main battery, to remove and replace the steering wheel buttons assembly (assuming the airbag can stay plugged in)?
Any help greatly appreciated
