So my central locking works fine if I use the key on the passenger side but if I use the key on the drivers side it only does that door and does not activate the central locking, the same happens if I look the door from the inside.
I thought it may be the actuator so went into the door and unplugged the lead.
I worked out which was the constant live and neutral, I presume the third wire is the activation for the central locking. Applying power to the third wire did nothing, therefore I presume it's more likely to be an issue with the wiring that the actuator.
I appreciate it's a vacuum system and pump under the rear sea but....
I have no idea where the wiring goes, whether there is a central control unit or where the problem could be.
Anyone had this before or have a wiring diagram or can explain whether there is a control unit, jct box etc? If I could trace that wire I could check it for continuity... Which may help.
