W202 dash light broken - how to replace?
Discussion in 'Interior' started by philepo, Feb 23, 2010.
  1. philepo
    philepo Hardcore MB Enthusiast
    294
    Jun 5, 2009
    Car:
    C270 CDI (2004 w203)
    Hi
    Does anyone know how easy it is to replace a faulty light in the odometer / mileometer?
    I'm guessing that if all the other lights are on then this isn't a separate fuse?
    Do I risk setting off warning lamps / air bag faults by diving in there?
    Cheers.
  2. C230kompressor
    C230kompressor Hardcore MB Enthusiast
    407
    Nov 18, 2009
    Car:
    1997 C230 Kompressor SPORT(SOLD) ---1993 C180 ESPRIT(SOLD)---1989 190E Cosworth REP(SOLD)
    hi there do you mean the little LCD readout?
  3. chopp3r84
    chopp3r84 New Member
    5
    Feb 24, 2010
    dumfries scotland
    Car:
    c180 classic
    i hit a speed bump and mine went out
    i gave the dashboard a bang with my hand they went back on
  4. W202lover
    W202lover New Member
    16
    Jan 27, 2010
    Car:
    W202
    C230 kompressor i got this problem my milage dsnt show clearly its like when u have some dead pixels u know ? how can i fix that
  5. C230kompressor
    407
    Nov 18, 2009
    Car:
    hi there
    IIRC this is quite a common fault!
    i dont know weather there is an easy fix but i have seen verious fixxing kits on ebay! there might some one on here who has done it before!
  6. OP
    OP
    philepo
    294
    Jun 5, 2009
    Car:
    It is the milometer readout that is now dark. The LCD is working cos you can see it in day light or with a torch, but the back lighting has gone. A bulb? Any ideas how to get at it? Cheers!
  7. Dec
    Dec Hardcore MB Enthusiast
    3,990
    Jul 28, 2004
    Car:
    C180,A. September '97 48k
    The cluster has to come out, easy if you have adjustable steering, the ignition must be OFF while the 2 connection plugs to the rear of the cluster are disconnected otherwise you will have an airbag warning light on all the time, requiring a reset at dealer. Steering wheel removal is not required.
    Cluster hooks … Removal and Replacement of Expansion Valve
    Cluster removal… 202Tech Instrument Cluster Removal
    Dec
    This may not be exactly the same as your car, depends on year of your car.
    [​IMG]
    [​IMG]
    6 people like this.
  8. OP
    OP
    philepo
    294
    Jun 5, 2009
    Car:
    incredible reply, cheers!
    1 person likes this.
  9. W202lover
    16
    Jan 27, 2010
    Car:
    W202
    Dec , thanks a million for the post , but what should i do to fix the dead pixels ? if you could help me with that ill be grateful !! ill post a picture soon of my instrument cluster to show what i mean
  10. Supacool1
    Supacool1 Hardcore MB Enthusiast
    328
    Mar 25, 2010
    Basingstoke
    Car:
    C250TD-T
    Dec you are a legend! That is really good to know!
  11. Dec
    3,990
    Jul 28, 2004
    Car:
    I know what you mean alright, I don’t know a lot about your particular problem, my reply was aimed at Philepo, others may be of more help however it would seem that you have two options;
    Pay for the repair … Cluster Repairs UK - Instrument cluster speedometer repair, correction, modification and spares.
    Fix it yourself, I believe this involves packing out the ribbon wire that feeds the LCD screen, contact is lost between the ribbon at the PCB board resulting in your symptoms. See… Auto Repair Tips: February 2009
    Dec
  12. OP
    OP
    philepo
    294
    Jun 5, 2009
    Car:
    cannot get this method to work
    Dec,
    I tried this and the cluster will not budge. I decided not to force too much incase i break anything. How long are the prongs on the end (the hook bits). Mine were 1 cm long.
    Cheers, Philepo
  13. Dec
    3,990
    Jul 28, 2004
    Car:
    That’s way too much, about 5mm is about right, there are exact measurements and design in a picture if you scroll down in this link here… Removal and Replacement of Expansion Valve
    When you are pulling make sure the hook handle is horizontal at all times.
    My hooks arent a great example but the do the job ok.
    Another method is to remove the panel under steering wheel at driver’s knees and push the cluster out from behind.
    Dec
    Edit
    This is what can can happen if you get it wrong and don’t keep the hook handles horizontal when pulling, hook slips and tears a chunk out of the glass on the way out.
    Solution to that is to get another cluster from a scrap yard and swap over the front, glass part of the cluster.
    Dec
    [​IMG]
  14. vijilants
    vijilants Hardcore MB Enthusiast
    2,169
    Jan 23, 2007
    London
    Car:
    C320CDI Sport W204
    As per Dec's post above , the hooks are way too long.
    I have done mine before and and it was very tight to remove, so I had to push it from from behind as well as tugging it with home made hooks.
  15. OP
    OP
    philepo
    294
    Jun 5, 2009
    Car:
    Thanks for the advice. I am going to leave this job. It is one of those things that irritates me that it is broken, but I would be unbelievably cheesed off if I broke the glass or set off a warning light.
    Not worth it! Thanks tho.
  16. W202lover
    16
    Jan 27, 2010
    Car:
    W202
    Dec , i just choose the short way and got it fixed at a local shop :) it just cost me like 25 pounds .... but its so worth it , i can finally see the clock and the temp. and the km reading lol !
  17. Dec
    3,990
    Jul 28, 2004
    Car:
    Its an expensive bulb though. As long as you have the ignition turned OFF while the 2 connection plugs to the rear of the cluster are disconnected then there is not a lot that can go wrong in doing it yourself, however you can brake the cluster alright, been there and done that but one from a scrap yard…£20… solved that problem.
    Dec
  18. herveybaymb
    herveybaymb New Member
    17
    Sep 2, 2011
    Queensland, Australia
    Car:
    1993 300CE & 1998 C180
    Where to order bulbs
    Great help, same dash as mine, but where can I buy complete replacement bulbs, with holders? I have been offered bulbs only and 1.2w not 2w! Is there a UK site I can order from as I live in Australia.
  19. Dec
    3,990
    Jul 28, 2004
    Car:
    Your local MB dealer will supply .
    Dec
    Edit; picture updated
  20. Nasco12
    Nasco12 Hardcore MB Enthusiast
    368
    Jul 18, 2009
    Twickenham
    Car:
    W202 C240 1999 Green; Previous: W202 C200
    Thanks for this, Dec. I've just replaced a general illumination bulb and the mileage bulb (and broken the display glass into the bargain - superglue is holding it all together for the time being.)
    In doing so, I found out that facelift bulbs are different. They are all 1.5w. This even managed to confuse the dealer.
Share This Page
