Wild1
- Nov 21, 2016
- Location
- Fraser's Hill, Malaysia
- Mercedes C200 Estate / Mercedes E250
Hi all, I wonder if there is a problem with the internal computer or wiring!
I have recently purchased a 2001 model C Class estate w203 chassis, It is an import to Malaysia where I live from the UK. I might also mention this is my first Mercedes.
The car runs like a dream (so far) however I am slowly finding little things that are not correct,
I have consult workshop light comes on SRS which the previous owner says it has been like this for four years and he keeps taking it back for a computer reset.
How do I find out what is wrong here?
Every time I turn off the car and remove the key the clock resets to 12:00 but this morning I notice that actually everything resets the trips after start and trips after reset although I am not resetting anything. Is this a computer issue?
Where is the computer if this is the problem and how to fix this?
The climate control operates the fan but the airflow cannot be changed on the control unit, The heater does not heat when the temperature knobs are turned.
Is this likely a control unit problem or something deeper?
The electrically heated seats don't seem to work either.
These may be non major issues or they well be more serious, I am keen to slowly get things back the way they should be if I can get some guidance. I have ordered the Haynes book from the UK but not yet arrived so i am still in the dark a bit.
Hope someone can shed some light onto some possible causes and fixes.
Attached is epic of my car.
Thanks in advance.
Thanks in advance.
