w203 misfire lack of power then cut out HELP :(
Discussion in 'Engine' started by nicom7810, Apr 1, 2014.
  1. nicom7810
    nicom7810 New Member
    Apr 1, 2014
    Torqyay Devon
    mercedes c class w203 220cdi
    I have a w203 class 220cdi, at first the power just went with the car knocking then cut out, so we replaced two injectors, 3 and 4, it started but still has a horrid miss fire and knocking. We then looked and the oil was all clumpy and sluge like, so we took the rocker cover off and cleaned all the cams and put some fresh oil in with an oil flush (low ash oil) but still the same and has a and very bad misfire, any thoughts? this is killing me lol.
  2. BlackC55
    BlackC55 Authorised Forum Sponsor Authorised Forum Sponsor
    Feb 8, 2007
    Horndean, Portsmouth, Hampshire, Southsea
    C43 AMG with a 55 engine and supercharger, MK1 Caddy, S500, etc
    Check the injectors again. If they are ok you need to do a compression test.
    1 person likes this.
Share This Page
