I have a w203 coupe first gen on 04, when the car is parked up for a day or two on the street with a slight gradient. When I pull off I get a few clonk noises from the rear originally thought it was the handbrake shoes not releasing as had a problem with pedal not returning properly these have all be checked and cleaned up and works fine now.
Once the car has moved like 10mtr doing acouple clonks then the noise is gone, and is fine even on bad roads and won't come back till its sat for awhile again. So thinking its spring related would a broken spring do this?
