W203 Reverse activated 12V supply
Sprint-Man
Newcastle upon Tyne (Area)
W209 CLK 240
Where can I pick up a 12V supply that is activated by selecting reverse on my C180K (05 Saloon/Classic), I'm fitting a Parking Sensor and the current draw is minimal, any of you experts already installed one?
Or if the rear light signal is too low, use a 4 pin relay and find a good 12v signal and use the reversing light signal to trigger the relay.
From the parktronic socket on the rear Sam.
I've been told it's the blue and grey one, brown is the earth. Not 100% sure
You could pick up the feed via the switch on the autobox, I believe it sits to the front right of the gear shift lever. I found it to be less hassle to just run a wire from my rear light cluster back to the HeadUnit.
Take a feed from the reversing light at the light cluster . Ive fitted these systems countless times , very easy .
Spot-On, Blue with a Grey Tracer it is, many thanks!
