amazighman
- Apr 22, 2016
- CLK 430
Hello guys.
My daily driver c180 Kompressor w203 devlopped an annoying fault causing all driver door electricals to fail temperamentally , I though for sure it has to be the commo fault with door module so I bought a replacement and tested it but it turned out the wiring was not making a proper contact in one of the unions under the passenger sill trim.
After unplugging and cleaning that union which solved the problem I ended up triggering an SRS restraint system at fault error which I couldn't clear....I am sure I must have unplugged the side airbag while ignition is on.
Any ideas how to get rid of this annoying warning light? Any cheap diagnostic tool that can clear it or trick? Orbi must take it to a garage with proper gizmo? Is it expensive?
I ve heated of autel diagnostic tool can clear this bu they are about 80 pounds.
Any inputs are appreciated.
Cheers
Cheers
