W203 suspension items
C32Graham
W126 300se E34 520
Morning guys,
I had the following MOT advisory, which arm would this refer to?
Right front lower (forward) suspension arm ball joint.
Also;
Rear antiroll bar has play in pin/bush - Is that droplink replacement time?
Thanks guys
The front steering hub is held in place by two arms, each of which has a rubber bush at the body end and a balljoint connecting it to the hub. Wear in the bush and/or the balljoint is not unusual.
If you look at the arms, the front one connects to the body ahead of the steering hub, the rear one connects behind it.
You require the front lower arm made from alloy, the other is steel.
My guess is rear anti roll bar bushes unless it stated a side then it would be links.
Thanks Guys, ordered via Car parts 4 less. £76 delivered.
Does anybody know where I can get the Torque figures?
