Freeform
Hello,
Regular reader but (one of) my first posts - as most questions I have already found the answer here.
Problem with my 2008 W204 C320 CDI (OM642, no DPF), 88000 miles.
This week, Monday morning, I encountered a new issue: on starting out for the commute (about 75 miles of mixed & motorway) I noticed I had little power - not enough to cause the transmission to kick down, and struggled to get up to speed on the on-ramp to M25.
I pulled off at services, keyed off, waited, keyed on and continued with power restored.
Nearer the office, I encountered traffic and, when that cleared and I accelerated down the on-ramp, the power had gone again. I arrived at work.
No fault indicated.
Lunchtime, went for a quick test drive and all the power was available (there was little traffic). Again, on the journey home, and both ways on Tuesday, there was no problem.
Today, Wednesday, I set off monitoring with the TorquePro android app; OK on starting off but there was slow traffic before joining M25 and accelerating down the on-ramp there was no power and boost registered zero. I pulled in to services, key-cycled and continued with boost and power restored. All OK until I hit the traffic nearer my office and lost boost. This time there was a fault and I had time to log: P0237 - Boost sensor A circuit Low.
I key-cycled once, boost returned and I arrived at office.
Lunchtime, performed fault scan with Carly for Mercedes app: Code 119E00 'no explanation available' and OBD00 P0237, as above. I am fairly sure P0237 is just a symptom of boost not matching the engine control module's expectation.
There appears a pattern developing; the lost boost condition occurs when the care is in traffic, at little or no load. On boost, I don't hear any boost leak.
as it has just occurred this week, I have not had the opportunity visit anyone for a STAR diagnostic session.
Help and advice appreciated. I can measure and understand engine parameters with TorquePro or Carly.
With thanks,
Andy
No fault indicated.
With thanks,
Andy
