W204.9 2011 xenons adjustment to European beam
xfish
W204.9
Hi (Noob here)
I have RHD W204.9 (2011 facelift estate model) with xenon lamps.
From what I can find online I should be able to change the lamps from UK to European beam.
How do I do that? Through the computer or is there a lever which I need to switch manually?
Any help will be appreciated.
If you have the Intelligent Light System fitted, it is done from the on-board computer, using the scroll buttons on the steering wheel.
Scroll to Settings menu then choose Light Settings.
Then scroll through to Dipped Beam Setting.
You can then choose Left or Right Side Traffic.
Note, If you change it to Right Side Traffic you will lose the Intelligent Light System Functions.
Thank you Gallon it worked like a charm
