gibsonk
A quick question to see if anyone has fit a D6 III to a w204 C350CDI
I received my box today (204-736-10), this was previously fit and removed by Mercedes in Ireland before i owned it.
The online fitting instructions seem to be different to the process for my car.
According to the instructions i have connectors for the following
QCV
Common rail pressure
Injectors 1 and 4
Boost Sensor
Special Temp Sensor
After a lot of head scratching my box connected to the following
Injectors 1 and 4
Boost Sensor
I have no connection for the QCV on the loom it wont physically reach, and the instructions are not clear if my car requires the Special Temp Sensor or not.
The instructions show this special sensor connector looping back to itself if not used, mine physically wont loop back on itself and the instructions do not show you where this should be connected to if required.
I assume its for the exhaust gas temp sensor and i think the connector is located next to the Common rail pressure sensor, it certainly fits there but without clear instructions i left it unconnected for now, i guess its so the PowerXtra knows when a regen is taking place
I have email Brabus but wondered if anyone had any insight or correct fitting instructions for my car.
Many thanks in advance.
QCV
Injectors 1 and 4
Boost Sensor
Special Temp Sensor
Injectors 1 and 4
Boost Sensor
