W204 Dash Images
David J
Lanarkshire
Mercedes CLS320 CDi
Firstly apologies if this has been done to earth. Recently got a 2012 W204. When I start the car the dash displays a picture of the side of a C class and 3 torsos. Ive researched this today and discovered that this relates to the rear seat belts not in use, can this be turned off ? Secondly Ive seen pictures of the dash displaying a picture of the front of a C class - how do I get this instead of the side and 3 torsos ?
I'm not aware that you can change anything here, but if you press the OK button on the left-hand steering wheel switch cluster when the warning appears, it will revert to the normal display.
Ernie
Have you got command online with dual display? Dual display has the picture of c class sideways on startup, on mine anyway.
Currently got an A200 courtesy car on a 66 plate, non-command, with audio 20, it does the same thing.
On my 2014 W204 it shows the image of the front of the car inside the speedometer for a few seconds on start-up, then the image goes away.
And I don't think you can cancel the rear seat belt check (though as ernie said it goes away after a couple of minutes or if you press 'OK').
I never get the image of the front, only the side. Maybe its a software update or something ?
Optional extra, it cost me £475
On my 2014 W204 it shows the image of the front of the car inside the speedometer for a few seconds on start-up, then the image goes away...
It looks exactly like the start-up image on the MBclub mobile phone App.
In my case it was a consolation prize for not having the Karl Benz windscreen signature.
