ShaunB, the update takes 2 1/4 hours - about 1 3/4 of which is DVD1, the rest DVD2 (it will ask for disc 2 when it's ready).
Empty the CD changer first. Then start the engine, connect your battery charger to the battery, switch the engine off but put the ignition back on so Comand does not go to sleep (this minimises the possibility of a voltage spike when you connect the charger from doing mischief to the SAM's).
Insert DVD1, it will autorun. About 1 3/4 hours later it will ask for disc 2 - eject disc 1, insert disc 2. About 30 minutes later it's done, eject disc 2 and put on ebay.
1 small wrinkle I've heard about - it appears early 204 Comand systems had a smaller HDD than later ones, the latest NTG4 update is too large for the early HDD - but you don't find out until the update stalls at 90%!!! Suggest you ask Comand.co.uk (Alfie or Richard) how to find out if your HDD is big enough for the latest update! Please post on here so I can check mine as well!!
What if one doesn't have a charger?
Just drive about for approx 2 hours
