Dizzy
- May 30, 2015
- Reliant Robin with a Mercedes badge.
Hi, i have purchased a tracker unit which features a remote cut-out facility. This is basically a relay which is wired inline into the fuel pump(?) circuit (using high amp cables) and operated by the tracker unit via a gsm signal (text). My question is:
Could any members advise on where in the loom this can be fitted on a diesel W204 c class? I'm not sure whether the fuel pump power comes from the front or rear sam nor indeed where the cable runs. Also, would fitting this into the loom have any affect on the canbus/ecu etc. and turn on the "check engine" light?
Any advice appreciated.. thank you.
