steveoelliott
- Mar 8, 2013
- CLK 230K W208
Hi all,
Today when I went to use my car I noticed the guard / plastic corrugated bit that usually sits around the selector lever (to prevent dirt / debris ingress into the mechanism) has disappeared. I know why this happened since last time I used the car a wire got stuck in there (fell out from the cubby hole below the stereo) and I struggled to remove it.
Obviously this is a concern since if something falls in it could stop me selecting a gear. I will be extremely careful and have nothing loose in the car now
But... I obviously need to get it fixed. How much of a job is it? I know how to take the surrounding panel off but don't really fancy opening up the mechanism itself so will probably take to a specialist.
Is it pretty easy to get to once the selector is removed from the car? Or does the whole thing have to be stripped to get to this part. I understand it is the shutter, listed here as part 113: FLOOR SHIFT USED WITH AUTOMATIC FIVESPEED TRANSMISSION 722.6. Fits: 1999 Mercedes CLK 430 | Mercedes-Benz of South Atlanta
Thanks...
Thanks...
