coneybiller
Afternoon all. I have an E320cdi 2002. I've had a squeak from the belt area for around a month. I've ignored it as it only happens at idle, once warm it disappeared all together.
The other evening I arrived at work and it sounded like I had an enraged budgey under the bonnet! Looked into it and it was coming from the alternator area. So I thought to myself I must get that sorted. The next day I had forgotten about it, got to work and there was the worst rumbling noise ever! It actually sounded like I had a cam lobe that was flat and the noise was coming from all over the place!
Took it steady and just got onto the M4 and the alternator light came on and the steering went heavy. Pulled straight over and could see the belt was stationary. The alternator pulley had completely sheared off the spindle. Recovered from Reading to Cheltenham with the most self centred, chatty, recovery man I've ever met (doh).
Luckily for me it had done no more damage. Not so lucky is the fact I thought it was going to take 5 mins to replace the pulley... even with the special tool, we could not get the remains of the pulley off of the spindle. Even removed the alternator to try and remove it. I had then found that the bearings were all exposed and dried out on the alternator itself. As I needed the car ASAP the only way forward was to get a new alternator... £425 later and 6hrs of graft(including waiting for parts to arrive and lunch) she's fixed! That was trade price too, GSF car parts wanted £848 retail!
Needless to say, If you hear a squeak or a squeal from the belt area, get it fixed ASAP!
