W210 e300 td power boost
andy75
norfolk
merc e300 td w210
Hi lads,
what is the easiest way to gain few more BHP on my e300 td w210
Thank Andy
Flashing Map sensor
andy75 said:
Hi lads, what is the easiest way to gain few more BHP on my e300 td w210 Thank Andy
If you want "real" power you should consider a modified diesel pump. Is your engine code OM606 ? If it is, then you can get big power for not a lot of monies. Speak to Diesel Pump UK. They build some superdiesel Mercs with insane power. HTH
https://www.dieselpumpuk.com
Seek out the STD forum. Friend of mine has got socketed chips for his 605 ECU, from a chap in Ireland - done the job, it seems!
