I have a slight fuel leak that seems to be coming from the joint between the Injector pump and the fuel solenoid (black plastic). There are two bolts that hold the solenoid on to the pump and a small 'O' ring that seals the two. I have had it apart and all looks OK but I guess it just needs the seal changing.
Is this a common leak point and is there where else that tends to leak?
Starting after re-assmbly is a bit slow but I guess this is just a symptom of the air needing to bleed out.
