Mercedesstar
- May 1, 2012
- S320Cdi
Hi all
I attempted to fix my foglights on my `99 E320 CDI today till the rain put a stop to it. I have bought a replacement foglight for the drivers side front, which I fitted. I turned the lights on and tried the front foglights, but they were not working. I had a look at the rear foglights and only the drivers side was working. I replaced the bulb in the left hand side but still nothing. I tried to switch the 2 light bulb fittings around and the left side fitting was working on the right hand side but the right hand side fitting was not working on the left side. So must be something else. I didn`t get a chance to check the fuses before the rain set in, but certainly for the rear fogs it must be something else since the right hand side is working ok. If the fuse for the front fogs is ok, has anybody got any suggestions as how to remedy the problem?
Thankyou in advance
Martin
Thankyou in advance
Martin
