W210 Handbrake Ears - collapsed in brake drum !!!
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by datripsta, Sep 5, 2017.
  1. datripsta
    datripsta Hardcore MB Enthusiast
    126
    Jan 20, 2012
    UK & Hungary
    Car:
    E320 CDI ( S210 & S211 )
    Bit of an odd and rare issues
    Looks like my right rear hand brake has completely collapsed in the drum and ripped the handbrake ears into bits. I heard it all get crushed up when I was diriving. Lucky this wheel didn't get jammed and cause more problems. I've taken the disc off and removed all the parts so its ok to drive but handbrake is only working on left side.
    Cant find any repair info relating to this.
    EPC doesn't seem to list the parts either. Cable end seems to be ok but the ear mechanism is in bits and way beyond usable. Will I need a replacement hub with the ears attached or can I just take the ears from a scrap car as Merc are struggling to find the part Ill fail the upcoming MOT if I don't get this sorted in the next few weeks.
    The ears are the part that expands and contracts when the handbrake is applied/released and links to the shoe mechanism to apply/remove pressure to the drum. I have a replacement drum shoe set along with slings and adjuster on the way. Its the ears that are my problem :(
    Any pointers are hugely appreciated
  2. Codger49
    Codger49 Hardcore MB Enthusiast
    1,157
    May 21, 2015
    South Kent
    Car:
    W209 CLK500, CLK280; W168 A190; E46 325i
    Are the 'ears' what EPC calls a 'shackle' and WIS calls an 'expansion lock'? (The expanding mechanism inbetween the shoes at 180 degrees to the shoe adjustment screw?
    If so, they are A 201 420 05 89 for a 210.026/226.
    2 people like this.
  3. OP
    OP
    datripsta
    126
    Jan 20, 2012
    UK & Hungary
    Car:
    amazing thats it! huge thanks. Looks like I can get aftermarket too if its stupid money from merc.
    There is a part that connects from the cable to one if the ears. If thats mashed as well do you know if thats available
    image is here https://goo.gl/images/Rcmm1G
    Youll see the part that connects from the back of the hub ( jsut the left of the green arrow with the round pin in the middle ) that has the cable attached to it. whats left on mine did look ok but after seeing these pics it may need replacing also.
  4. OP
    OP
    datripsta
    126
    Jan 20, 2012
    UK & Hungary
    Car:
    looking at pics I think that maybe the end of the handbrake cable so possibly a fun job and do the cable also.
  5. Codger49
    1,157
    May 21, 2015
    South Kent
    Car:
  6. magsbert
    magsbert New Member
    9
    Oct 25, 2012
    Car:
    c 180 coup
    Good read all replies are good advice,
Share This Page
