coneybiller
Well I've just had all of the rear multi link arms replaced. It now creaks and feels very crashy and unstable when going over bumps. I've also noticed that the NSR is slightly lower than the OSR. The shocks seem to be returning with 2/3 bounces and the springs aren't broken.
I actually nearly lost it in a 50mph contraflow section of the M4 yesterday. After crossing the central reservation area following the lane, I went over a grate and the back end went all squirrely and a lot of correction had to take place to keep it in a straight line! Unnerving is an understatement! It seems to do this also when going over a pothole at slower speeds.
Had the car up on a ramp since the arms were replaced, but cannot see anything obvious! All bolts are tight and all seems present and correct!
I'm wondering if the person who carried out the replacement, actually tightened the arm bolts without a load on the hub (IE suspension compressed) so to pre-load the bushes? Could this be a possible cause?
Do you think I should try and back off the nut and bolts and place a jack under the hub to simulate suspension load, then re-tighten the nuts/bolts?
Cheers
Ben
Cheers
Ben
