ro80rob
- Jan 23, 2011
- Location
- Warrington, Cheshire
- 83 W123 230CE, 01 W210 E200, 72 NSU Ro80
Hello
I've searched high and low on this problem and I've not come across exactly the issue I have.
Car:- 2001 W210.035 E200 (not the K model) with 5 speed 722.602 auto Transmission
Mileage:- 108.000 miles
I've had this car for just over 1 year and done 10,000 miles in it. It is the nicest car I've had, and I'm rather choked that it's developed a fault. This is despite the car being very cheap (why I bought it).
The transmission howls/whales above about 20 miles an hour, especially when its cold. As the box warms up, the noise will virtually disappear, but can be just heard at around 60 MPH.
When I say, whales, I mean that it can change note (it has a couple of resonances which it can jump between), and the note is also speed dependant. Volume comes and goes from loud to almost inaudible. Its not a harsh sound.
This fault has developed over the past month and I've continued to use the car every day for work, as, despite the noise, the transmission and car performs perfectly.
There is also no unusual/additional noise from the engine/transmission if I rev it in Park or Neutral. In other words, I don't hear any pump noise from the autobox hydraulic pump.
I also ran the car from cold up and down the road whilst using the 'manual' selection on the lever (never done that before) and I get the same noises regardless of which gear I'm in (above 1st anyway). Also the noise persists under load or on over run.
Things I have done..
When I got the car, I changed the transmission fluid and filter and the centre prop bearing as that was making a racket on over-run.
Since the noise started, I've changed the diff oil (though I'm convinced the noise is coming from the transmission region) and the centre bearing and carrier (again). There are no transmission oil leaks (level is spot on) and the diff doesn't leak and had good (now new) oil in it.
Tomorrow, I'm having the transmission oil and filter changed again (genuine MB filter). I am also considering putting some of that Lubegard Platinum additive in as a friend who had a transmission issue on a BMW was given this to help it (not selecting reverse) by a local auto gearbox specialist and it pretty much cured his fault. I'm wondering if the new spurious filter I fitted 12 months ago has maybe failed/blocked up in some way and its a hydraulic noise I'm hearing as the pump tries to draw fluid through it.
Could it be one of the solenoid valves in the box sticking in some way?
I am clutching at straws.
So...
Anyone care to advise me on what to do/test/fix next?
That would be great.
Cheers... Rob.
So...
Cheers... Rob.
