Further to Alps' how to guide below. I have now fitted this option into my own car and will add my experience.
You will actually need 18x rivets, part number 0009915532.
There are 2 versions of the adjustable cross rail, 1 for the saloon and 1 for the estate. The saloon version is shorter and will allow you to store the cross rail on the side, part number 211 846 01 62, price as at 18 September 2015, £111.00 + VAT (20%).
Thank you Alps for posting the guide in 2012
Extract from Alps' guide:
Fitting of Easypack system option code 942 load compartment package
In my mission to add another option to the car the Easypack kit was next on the list. This is a system MB developed to stop stuff flying around in that huge boot!
To start off with you need to buy the following
- 2 x Floor Rails (L&R) (come with ends and guides)(2118400526/2118400626)
- 6 x screws to fit rails to brackets (000000003396)
- 2 x long brackets (L&R) (2118430514/2118430614)
- 2 x short brackets (L&R)(2118430314/2118430414)
- 6 x screw locks (0049941245)
- 16 x Rivets to fit brackets to floor(0009915532)
- 2 x Bolts for long brackets (000000003853)
- Easypack case with fittings
- Easypack adjustable cross rail
Tools needed
- Drill
- Good self centering metal drill bits (same size as the rivets)
- Stanley knife
- 10mm reverse torq
- Rivet gun (good one)
- 8mm Torq
- 10mm Torq
Tools needed
- Drill
- Stanley knife
- 10mm reverse torq
- 8mm Torq
- 10mm Torq
