w211 keyless go opening only drivers side
Discussion in 'Electronics' started by Alps, Jan 27, 2017.
  1. OP
    OP
    Alps
    Alps Hardcore MB Enthusiast
    6,778
    Nov 29, 2002
    London\Essex
    Car:
    E63 Weistec AMG, E55 2004 Silver(SOLD), C36 AMG 1997 (SOLD)
    I bet it was mate, well done on finding it, for me real work was the reason I didn't find the time to fix it. lol
  2. pmcgsmurf
    pmcgsmurf Hardcore MB Enthusiast
    436
    Feb 22, 2010
    Scotland
    Car:
    E55 AMG W211, E250 Sport W212, E220 Avant. W211 (and some Imps)
    Was well worth it in the end, great result and gives you a feeling of achievement and that the gremlins can't beat you.
    Alps likes this.
  3. pmcgsmurf
    436
    Feb 22, 2010
    Scotland
    Car:
    Drat, went to move the car at work today and keyless entry wouldn't work.
    Quick scan on Star and the Keyless Door Module is no longer there on the CAN bus, got power to it and the CAN connections so looks like this one has failed too, proper bummer.
  4. OP
    OP
    Alps
    6,778
    Nov 29, 2002
    London\Essex
    Car:
    arrrrgggghhh... you`ll get there mate!
  5. pmcgsmurf
    436
    Feb 22, 2010
    Scotland
    Car:
    Let me speak out lout to gather my thoughts on what may be wrong. ;)
    1. Right module fitted was faulty.
    2. Left module had broken wires in door hinge, worked when this was fixed.
    3. Right module goes faulty after a few days (little use).
    4. Fair to assume that if fitting another this may also go faulty again.
    I'm guessing the wiring on the right side may be the same and causing intermittent connections.
    Gonna strip this out tomorrow morning to see.
  6. OP
    OP
    Alps
    6,778
    Nov 29, 2002
    London\Essex
    Car:
    id check it before putting new module in; definitely
  7. pmcgsmurf
    436
    Feb 22, 2010
    Scotland
    Car:
    Exactly what I did this morning, stripped drivers side wide from the rear door hinge.
    Couldn't find any broken wires so was starting to worry, then after cleaning up a bit found this:
    These are power, ground and CAN wires.
    My assumption is that the wire have been wrapped so tight that the CAN signal has been shorting to the +12 or GND connection.
  8. OP
    OP
    Alps
    6,778
    Nov 29, 2002
    London\Essex
    Car:
    i think you may have found it there Pat
  9. pmcgsmurf
    436
    Feb 22, 2010
    Scotland
    Car:
    Fingers crossed, but when all other possibilities have been eliminated, you are only left with the obvious.
    Hopefully get another module to test over the next day or so.
  10. pmcgsmurf
    436
    Feb 22, 2010
    Scotland
    Car:
    Had some time today so finally managed to get round to fixing this.
    I removed the wires where the insulation was cracked from their connector housings so that I could slide some heatshrink sleeving down them, didn't want to cut them.
    Didn't want to only use PVC tape as thought it would look a bit dodgy although I did use a small amount to further insulate the crack on the wire insulation.
    Checked all the other wires then wrapped the harness again in fabric tape.
    All back together, tested and all locking & unlocking functions working correctly, thanks to Alps^ for sorting me out replacement modules.
    Funny thing I noticed though was that initially when testing on Star the modules reported Left/Right round the wrong way.
    Swapping them round had them reporting correctly via Star.
    That leads me to believe that although the modules have the same part number there must be some way to write to their memory to store their location.
    Anyone confirm this?
  11. pmcgsmurf
    436
    Feb 22, 2010
    Scotland
    Car:
    Arghhhhhh...................I think it hates me.
    Not been driven, spent all week inside being polished and waxed.
    Went to open the drivers door this morning and nothing, lock (push) button works but no response from the unlock (pull) button.
    Quick check on Star and the unlock button does not toggle when pressed, the lock button does.
    Looks like I may now need a handle!
  12. AMGeed
    AMGeed Hardcore MB Enthusiast
    7,474
    Nov 1, 2008
    Bournemouth/Poole Dorset
    Car:
    2004 W211 E55K ///AMG
    pmcgsmurf likes this.
  13. Will
    Will Hardcore MB Enthusiast
    9,707
    Jan 21, 2003
    Surrey
    Car:
    2004 S211 E55K AMG/1988 190E 2.3-16/1988 190E 2.5-16/2003 Porsche 911 3.6 Carrera 2 (345hp Powerkit)
    Have to say I’ve never seen or heard of so many issues with the keyless system before - you’ve been unlucky but on the plus side it should be good as new once sorted! :thumb:
    The handles aren’t all that expensive new, I think the last one I bought brand new from Mercedes pre-finished in 744 silver was around £150 including VAT and obviously comes with 2-years warranty etc.
    5 minute job to replace fortunately.
    Obvious test the handle manually with a multimeter first (and/or swap it over with another one for testing purposes)
    If you’re really keen and want to go for refurb from the place in the link I’ve got a cosmetically good keyless 744 drivers handle spare you could use if it helps.
    Will
  14. pmcgsmurf
    436
    Feb 22, 2010
    Scotland
    Car:
    Thanks, might be worth a try.
  15. pmcgsmurf
    436
    Feb 22, 2010
    Scotland
    Car:
    Cheers, should be, have to say when it works I do like it, never had it on any of the cars before.
    At around £125 net it would make sense just to order new rather than pay €99 plus the shipping charge to send the old handle.
    Just done that, the handles read, (useful for anyone else with similar problems).
    Open/Pull Switch 300 Ohms
    Push/Lock Switch 470 Ohms
    Checked the drivers handle and it had a notable squish when the Pull switch was actuated.
    Pulled this apart (now it is knackered), they have a 470 & 300 Ohm resistor inside connected to the 2 micro switches. The Pull micro switch is reading high impedance when pressed.
    Cheers, drop me a PM and let me know how much and what is wrong with it, maybe I could make one out of two!
Share This Page
