W212 E63 AMG suspension noise from OS?
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by AlexM, Jan 30, 2017.
  1. AlexM
    AlexM Hardcore MB Enthusiast
    184
    Oct 4, 2005
    Kingston upon Thames
    Car:
    W212 E63 AMG Saloon
    My E63 is currently at the dealer for investigation of a light knocking/tapping noise that is most noticeable when the car is cold. So far the arb drop links have been changed, as have the lower suspension arms (thankfully under warranty), but the problem remains. No obvious problems visually - what else is it likely to be? A problem with the strut? Anti roll bar bushes? Top mounts?. The car has done 23k and is a 2013 model.
    Any suggestions?
    Thanks,
    Alex
  2. AMGeed
    AMGeed Hardcore MB Enthusiast
    7,472
    Nov 1, 2008
    Bournemouth/Poole Dorset
    Car:
    2004 W211 E55K ///AMG
    Have the ball joints inspected carefully. Same symptoms on mine was a lower ball joint.
  3. HB
    HB Hardcore MB Enthusiast
    2,605
    Mar 30, 2011
    Car:
    E63 5.5TT, E350 CDI, C320 CDI, S3
    We had a similar problem at a similar mileage - both front top mounts believe or not.
  4. OP
    OP
    AlexM
    184
    Oct 4, 2005
    Car:
    W212 E63 AMG Saloon
    That's interesting. I did have to have one of the top mounts greased as it was making a squeeking noise as lock was wound on or off. That was also on the driver's side that the knocking/tapping appears to be coming from. Is there an easy way to check the top mounts?
    Regards,
    Alex
  5. OP
    OP
    AlexM
    184
    Oct 4, 2005
    Car:
    W212 E63 AMG Saloon
    surprise, surprise, I got the car back without any diagnosis - no fault found, and heard the noisie within a couple of hundred metres driving away.
    In fairness to the dealer, they did invite me to bring it back if I could find a way to make the problem apparent. We'll have to see if it becomes more apparent. The nature of the noise is a light knocking noise when the wheel is in bump/droop. ARB drop links and lower susupension arms were replaced under warranty due to deterioration (which is suprising in a just three year old car). MB made a 70% contribution to the warranty company, which is interesting. I wonder if there is a known issue with the inboard bushes on the lower suspension arms?.
    Admittedly I am being very fussy, but I can definately hear something and I don't think suspension should knock/tap over bumps.
    Regards,
    Alex
  6. sjmaxwell
    sjmaxwell Hardcore MB Enthusiast
    3,076
    Aug 15, 2003
    Chatham, Kent
    Car:
    2012 E Class E63 PPP, 2014 SLK 250CDI AMG Sport
    Did you get this resolved? Only ask as mine is in the dealers for a vibration issue when going over 80mph (there is a Xentry doc on this problem since 2010) but I also have this knocking when going slow over rougher surfaces. As there is no fix yet, Mercedes Technical have been guiding the dealer in fitting modified top mounts and other components and asked if I can fill a document in about how it performs. I'm guessing they are assessing how different changes are effecting the issue to see if a permanent resolution can be found :thumb:
  7. OP
    OP
    AlexM
    184
    Oct 4, 2005
    Car:
    W212 E63 AMG Saloon
    No still not resolved yet unfortunately. I think that the problem is drivers side top mount or the strut on that side. Can you share any information about the fix or the documents in Wis / xentry you mention?. Dealer says they can't hear anything untoward but I can pretty clearly. It sounds like a ball joint or similarly light sounding rattle.
    Any info on your case or how you initiated an investigation would be most welcome as it is still niggling me.
    Regards,
    Alex
  8. sjmaxwell
    3,076
    Aug 15, 2003
    Chatham, Kent
    Car:
    Its just back from the dealers and seems much better due a new modified top mounts (they are the same as the facelift model) and other parts that the dealer didn't list but they didn't all come in together so ended up another day in their workshop.
    Xentry doc attached
    • I.doc
      File size:
      23 KB
      18
  9. OP
    OP
    AlexM
    184
    Oct 4, 2005
    Car:
    W212 E63 AMG Saloon
    Thanks for that. Interesting Tips case, although presumably not relevant to me given my car is a face-lift model. I did have tremendous problems with high speed vibration, although this turned out to be out of limit road force imbalance that was resolved by replacing the tyres. My front top mounts required remediation under warranty for squeaking / screeching when applying lock while parking. I believe this is fixed with a new type of grease (at least temporarily)
    Regards,
    Alex
    Sent from my ONEPLUS A3003 using Tapatalk
Share This Page
