W212 Glove box light
Discussion in 'Interior' started by chyperie, Jan 26, 2017.
  1. chyperie
    chyperie New Member
    4
    Jan 6, 2016
    Car:
    Mercedes E350
    The glove box lamp has stopped working, I've checked the bulb and fuse are OK (and tried it with headlights on engine running). I assume it must be the switch or loose wire to/from switch but can't see it, is it part of the glove box lid catch? Any advice would be much appreciated.
  2. richard
    richard Authorised Forum Sponsor Authorised Forum Sponsor
    5,344
    Jun 10, 2002
    Berkshire, UK
    Car:
    MY04 SL55, MY17 GLC250d AMG Sport
    It possibly has to be dark outside
    Richard
  3. OP
    OP
    chyperie
    chyperie New Member
    4
    Jan 6, 2016
    Car:
    Mercedes E350
    I think I've tried that but I'll go and check in a bit!
  4. paulsweatbead
    paulsweatbead New Member
    9
    Jan 9, 2016
    Telford, Shropshire
    Car:
    E350 Avantgarde saloon 2010
    Any luck getting it sorted? My Glove box light only illuminates when the lid is half open and then goes off again when fully open. The fault is obviously at the actuating switch but I just can't see how you can access it.
  5. OP
    OP
    chyperie
    chyperie New Member
    4
    Jan 6, 2016
    Car:
    Mercedes E350
    Hi Sorry for the delay in replying, I've been out of the country. Quick answer is No. I think I'll need to take out the glove box to get at the wiring!
  6. Scrote
    Scrote New Member
    20
    Jul 1, 2017
    Norfolk UK
    Car:
    E250 cdi
    Same here! Did you find anything out yet?
  7. Chugg
    Chugg Member
    37
    Aug 16, 2017
    Car:
    E350 CDI Sport Estate
    I seem to have this issue too.....
  8. Scrote
    Scrote New Member
    20
    Jul 1, 2017
    Norfolk UK
    Car:
    E250 cdi
    Ok here we go, I have fixed this, it will be a common problem as it's a design fault. There is a Microswitch on the left hand side outside the glovebox assembly and it moves through 6" of travel as the glovebox is opened. The wire has to bend each time and mine had broken at the crimps due to fatigue. The fix goes as follows... Remove side panel near door and panel under glovebox. Remove trim panel above glovebox, undo 3 Torx screws along top of glovebox and one bottom left corner. Drop glovebox and you will see Microswitch and broken wires. Remove plug from Microswitch, carefully remove crimps, solder 5" of wire to crimps and reinsert into housing. Join wires and reassemble. I have taken a full set of photos for this procedure but don't know how to upload since photobucket stopped. Can email them if somebody wants to upload...
  9. Scrote
    Scrote New Member
    20
    Jul 1, 2017
    Norfolk UK
    Car:
    E250 cdi
    Codger49 likes this.
  10. OP
    OP
    chyperie
    chyperie New Member
    4
    Jan 6, 2016
    Car:
    Mercedes E350
    That's brilliant, many thanks
  11. paulsweatbead
    9
    Jan 9, 2016
    Telford, Shropshire
    Car:
    This sounds as if it's a job I need to do. Well done for fixing it. I'd really appreciate your set of photos to guide me on my way. It's pmartin007@blueyonder.co.uk. Cheers
Share This Page
