mkhoo
Hi guys,
I have an opportunity to purchase the factory fitted components for a W212 estate reversing camera which I understand to be:
1. Reversing camera that connects to the boot handle (just above number plate)
2. Cable from camera to control unit (and onward to COMMAND)
3. Cable from control unit to rear SAM
4. Control unit
5. Maybe - the estate boot handle is required too. Mine has what looks like a filled in cut out in the position
6. Maybe - a wire cover or something to stop the control unit bouncing around
I wish to install these components into my 2010 W212 Estate
From the internet I can see how to get into COMMAND engineering mode and enable the camera but I also have read on this forum that one needs some special code from MB to get this working.
Does anyone know which is true? Can I can simply enable the reversing camera in COMMAND to get this working after installation, or do I have to get an MB dealer to update some database before it works? I think I have COMMAND 4.5 but I'm not sure (What I do know is the SAT NAV takes 7 character post codes).
Before parting with money I want to make sure it is all worth it because the MB dealer will no doubt charge me for the privilege or maybe wouldn't do it at all which would be a total waste!
Thanks in advance.
/Marcus
4. Control unit
Thanks in advance.
/Marcus
