w221 Retrofit DAB and TV tuner
Merc-Man24
2005 E280CDi
Hi peeps.
I Have a TV tuner and a DAB receiver from a s class.
I also have a donor wiring loom but can't figure out what wires I'd need to help get this fitted in my car. My car is a non Harmon Kardon model. Does any one have any experience with this. Could I buy a wiring loom from somewhere.
You will need the antenna pack (top of rear window), and the antenna wiring loom (its a pig to remove from donor car) plus the wiring loom for the DAB and the wiring loom for TV. Also, if your car has Keyless-go and the donor does not then you'll need a new amp pack.
Is the donor car being scrapped - or do you need to leave it working. Did you get the DAB tuner bracket, and the Amp/TV-tuner bracket (or has your existing amp bracket got the slot for TV)
Talk to Alfie at Mercedes Retrofit Specialist - Comand.co.uk - he can quote for fitting if you tell him what parts you have. It is far from trivial, putting the wiring loom in is a pig and possibly have to take headlining out
Richard
The donor car is going to be sold next week. I need to crack on and take out everything before then . It's just a pig of a job but I'm sure I'll make something out of it.
