Water injection
Matt1e
Sunny Blackpool
2012 E63s AMG + performance Pack
I have recently been looking into the benefits of adding a water vapour into the induction flow.
Has anyone added a water or water/meth system into an M175 (V8 Bi-Turbo) ?
It's something I've mulled over though need to do a lot more research before committing to it. There are a good few benefits to it, but also a few pitfalls from what I've seen so far, hence my hesitance.
Have you any reason for wanting this mod? Just that there are a lot more ways, mostly easier, to get power out of this engine. What have you done so far with it, or is the idea to put it on a stock engine?
I don't know if you're aware, but Weistec are currently offering a system HERE, though a bit overpriced in my opinion...
Oh, and it's an MI57 engine by the way. ;)
The main problem is that it's not the all-singing-all-dancing affect that it's claimed to be.
To get real benefit you need to map the car for using the water/methanol mix, but that means you then have to use it unless you want to switch maps all the time.
Ideally you also want to be able to maintain a stoichiometric relationship of water/methanol to air charge, but that really means you need the system reading from the MAF or MAP sensors.
I decided it was all too much effort once I'd looked at it in a little more detail, but not until after I'd already bought the pump etc.
Wow, that looks rather expensive alright. Looking at it the controller looks like is a basic AEM unit. The unique parts seem just to be a one piece silicone hose to the inlet manifolds and an expensive reserve tank.
No I hadn't come across the Weistec install and typo on the engine model !
More interested in the fuel savings !!! :p
I had a vaporiser fitted onto an old XR2 Mk1 intake in the 80's and it made quite a difference even with just water. Not so sure with all the sensors now, how effective it is without full mapping etc.
Just a wandering thought really !
Is the fuel saving achieved by running more lean and using the water to prevent detonation? - It's not an aspect I looked at; I was just concerned with maximum boost pressure for minimum increase in charge temperature.
