We have a Samsung fridge/freezer with a chilled water dispenser & ice maker.
SWMBO rather cleverly lost a valuable envelope behind the fridge, resulting in me having to pull it out to recover the envelope.
Whilst it was out, cleaning seemed a good idea to get rid of 3 years of dust. To do this thoroughly, I removed a back panel to clean the dust & fluff from around the compressor and found a small leak on the drinking water supply pipe, where it joins the solenoid valve. It appears from the limescale crust that the leak has been going on for some years.
To fix the leak I need a new pipe insert & nut, like in the picture below.
I have those fittings for a 1/4" tube, but the ones I need are for 8mm OD tubing.
Knowledgeable members:- anyone know where I can buy these fittings?
