rossyl
Really appreciate your advice on how to deal with this situation.
So I own a flat. I'm a leaseholder. The freeholder is in charge of the external walls and roof. This includes the skylight, and there is no debate over that. He is under a duty to keep it in a good state of repair, and also make good any damage caused by repair.
It is a 3 flat converted Victorian house. The freeholder lives in one of these flats. So he is a neighbour as well.
The skylight has been leaking and has caused damage to the wood surrounding it.
It took the freeholder some 3 weeks to attend to this. He called someone round to fix it whilst I was on holiday. I returned to find dirt all over the carpet, and a broken light. The light was cheap, so I could deal with that.
However, the leak was still present. The freeholder called back the roofer, who has now fixed the leak but has left the glass in a mess. There is sealant all over it and it looks terrible. This adds injury to insult as the skylight looked awful before this, it has two metal bars running down the length of it - both have rusted and the paint is flaking off, it is also extremely dirty.
Before the roofer came out the second time I specifically asked for the roofer to wire bruish the glass. The Freeholder did not pass on this message, I asked him if this had ben done and he responded "no, no, they won't do that, he's just a roofer, he'll just sort it out".
The damage caused by the leaking window the freeholder also frequently says "if YOU get a ladder and a scaffold board you should be able to get there and paint it", or, "YOU can probably get someone up there to fix it". Never has he accepted liability.
The freeholder has, however, just had the whole of the front of the house painted. This includes the windows for his and the other leaseholders flat. I have no windows at the front, so mine were not done in this process. I cost will be split three ways, and so I will end up paying for maintenance to their windows. I do believe that the freeholder can split the cost for maintaining the property. For example, the costs to fit my skylight should be split between the three flats.
I'm intending to live there for at least another 3 years. I don't want to be in a constant argument with the freeholder. Especially as I am about to start building work, so will want to use the communal areas a bit more than i should. Also all the residents get on, and take deliveries for each other when people aren't in. For example, the freehodler was willing to take delivery of a bed for me.
So what's best to deal with this?
I have thought i might obtain a quote from my builder who is about to start work? Or obtaining seperate quotes and just letting him know I'm going to have the work done and I expect the cost of this to be split three ways.
Any ideas appreciated...
Cheers,
R
Cheers,
R
