bullyboy112
Just wondering, what's more reliable?
E320 CdI in-line 6, or the E320 CdI V6???
Sent from my D6603 using Tapatalk
The bore and stroke are interesting. My V8 is underquare (98mm bore and 90mm stroke) whereas the I6 goes totally the other way (bore 83mm and stroke 93mm).
I wonder why?
Where's Machtech?
I can only speculate. Quite a few straight sixes in the past were slightly undersquare so its not unusual for this configuration of cylinders*. It may be to do with "packaging" again narrower cylinders shorter /narrower block, or better low down torque characteristics at low revs may suit the electric starter /generator transmission package or it may be the emissions can be controlled better don't know.The bore and stroke are interesting. My V8 is "oversquare" (98mm bore and 90mm stroke) whereas the I6 goes totally the other way (bore 83mm and stroke 93mm).
I wonder why?
Where's Machtech?
Your petrol needs a bigger bore to get good torque from the stroke as it's much lower compression than a diesel. The higher compression of a diesel means it can have massive torque from a smaller bore, and the longer stroke all lends itself to efficiency.
The return to under square engines must have something to do with the adoption of forced induction. One limiting factor with under square engines was the linear piston speed and hence maximum revs. Now that almost all engines are forced induction, high revs are no longer needed as maximum power revs are relatively low. The advantage of under square engines was always said to be at lower revs due to the longer duration of cylinder pressure on each power stroke.
