Had an advisory on my MOT regarding slight play on front wheel bearings on my E350cdi Coupe, is this a diy job or should I take to a local indie .
Mercedes make wheel bearing adjustment easy. Unlike the old fashioned castellated nut and cotter pin that has discrete amounts of adjustment MB use a nut that is infinitely adjustable and is clamped in place with an Allen key. may sure to back off the brake pads so that they don't interfere with the feel. It's a very fine thread and if we knew the thread pitch the end float adjustment could be done by rotational measurement of the nut.
E.G. If the thread pitch was 1mm, then setting the end float to .01mm would entail rotating the nut out by 3.6 degrees which as markjay said is a smidgen.
Thanks for the input Guys, think I will get the indie to have a look at this for me, things have moved on since I last carried out works on my own car
