Which wheel bolts for a w201
gunning
Cornwall
800BHP Rothmans 911 / Range Rover / s212
What wheel bolts do I need for a w201 190e please?
I thought it was m12 X 1.5 35mm for alloys but it turns out I'm wrong.
I think the alloy wheel boots are around 60mm long - 20mm threaded, 20mm shank and 20mm head or thereabouts.
On some of the wheels (eg Sportline/16v) the head is deeper so it sits a little closer to the face of the wheel when mounted.
You can't use steel wheel bolts. And make sure if you're using non OE wheels or bolts, that you have the correct bolt seat (radius usually) and the correct amount of thread protruding - too much can foul the handbrake mechanism on the back.
