X164 radio reception
AndrewOl
Romsey
E350 A207
Have very poor FM in 2006 GL. Thinking of fitting aerial (FM/DAB) above front courtesy light rather than messing about with rubbish rear heater system. Any thoughts?
Cheers
Andy
When the antenna system is working as designed there are two antenna (a main and a diverse) and it works well (assuming you are not at the North Pole!!)
I suppose a separate roof antenna may well be slightly better, but sounds like your FM antenna amplifier connected to the rear window has failed and it's worth replacing it (about 10 minutes work) - but buy some spare clips for the rear door panel and some will break/bend and need replacing
Cheers
Richard
