- Sep 27, 2016
- Location
- UK
- Tesla Model S, Model 3 LR, Model X /// Previous: Jaguar XFR, Mercedes E320 CDI, C32 AMG, CLK 320
I believe I have finally found the reason behind my dreaded Xenon nightmare
See Star Bulletin: https://www.dropbox.com/s/pw394u7om0...B1].pdf?dl=0
I believe I need to order the relevant kit for the igniter replacement, and it seems to be not too bad of a job? Bottom page it mentions around 1 hour.
there are 2 kits and the way to distinguish which one is to check the manufacturing date of the headlamp.. (shown on the attached pdf) and the actual replacement procedure seems to be simply cutting off the old igniter and soldering in a new one?
The symptoms of my car seem to hint towards igniter, as the bulbs sometimes fail to ignite however when the car is switched off an on sometimes the bulbs will restart and work fine... sometimes they work perfectly all the time!
According to others the original ignitor (such as the one fitted in my car) delivered only 25KV to the bulb but this was then increased to 30KV later.
Now here I am confused
Perhaps, as the xenon bulbs in mine have got older they require more voltage to ignite so i am having these issues? could it be just a set of new bulbs could solve this? As this only started a few months ago
However I have also seen a post where someone has had the same symptoms as me except it was solved by a new ballast!
Conflicting info everywhere
Any help greatly appreciated
Cheers
Cheers
