£15 in my car gets it out of the garage!! )
If you are smelling Petrol, I would get it looked at straight away rather than risk a Fire, Get it seen to without further delay, I have seen too many Car fires and its not a pleasant sight.
BAZZER1
I've only smelt it once but if I do again I will have it looked at
Now I've done some motorway miles 200 miles for £30 @ £127.9 per ltr how do I work it out?
Had it looked at and there is no fuel leak! So don't know why I smelt fuel but as I said it was only once...
Now I've done some motorway miles 200 miles for £30 @ £127.9 per ltr how do I work it out? Thanks
Hope my sums are correct here but there are about 4.55 litres in an imperial gallon, so £1.279 /litre works out at £5.82 per gallon. £30 would buy you 5.16 gals and if you used this much over 200 miles then you were getting 38.8mpg on average.
You can tell us the amount you spent and the price per litre...why not just tell us the number of litres...then multiply by 0.22 (in your head) and you have the gallons...it's easy from there.
They may not be a fuel leak but I would put money on the charcoal canister being blocked. It is located by the fuel filter
