Sheffield Col
- Sep 16, 2015
- Location
- Sheffield.
- Mercedes 2014, C Class 220 Diesel Automatic Blutec W205
Any one on here had a go at this ?
hope the link works.
A lot of talk about them on another mb forum. People love themAny one on here had a go at this ?
I have just fitted this to a friend's W212. It is plug and play and works well. The only problem I had was that the car originally had Audio 20 and was previously retrofitted with NTG 4.5 which added a quadlock connector. This screen then adds another quadlock connector and fitting all the wiring back into the limited space was a nightmare. Should be easier with a factory NTG system. All the functions work well, the OEM display can be selected and the joystick and steering controls both work. The only thing he needs to do is switch between the factory head unit (CD/SD card) and select Aux to get sound from the screen through the speakers. Easily overcome as he can either BT music over or put an SD card in the unit itself and not use the factory headunit. He can then use the system's BT for phone too, rather than the MB unit.
Interesting. So this is a screen with an HU - where does the HU sit? Inside the screen?
I thought that too and I haven't looked into why it's not doing it. It may be due to the extra wiring not being correct, the aux port (possibly) not working or just my impatience.
Depending on the car yes. But usually you buy it all as a model specific kit from the supplier.So here in the UK we'll need to get a RHD bezel/bracket?
Thanks.Depending on the car yes. But usually you buy it all as a model specific kit from the supplier.
How much are these ?
Thanks.
The W204 and W212 will require a RHD-specific kit then.
