hi all I am new to this site an have a big problem with my 2002 108cdi , last year I had new injectors fitted , o rings on fuel rail done , new diesel filters an fuel pipes done van was fine until 2 days before the new year I drove to my daughters an stopped the engine went into the house for a bit then the van would not start all the lights on the dash come on then when you turn the key nothing , it would not even try to start so phoned breakdown , he came out an checked the battery which was fine an said he thought it was the starter motor got the van recovered to the garage I use he put it on the code finder an only one fault came up so I had a new starter fitted , he cleared the fault code now the van will start but stops straight away an when the codes are checked again the same code comes up you can't get to run at all any ideas ? someone has said it could be an imobiliser fault an that I need to get a merc mechanic to recode the keys or the computer needs replacing but with the amount I have already spent I am loosing the will to keep going please help any ideas would be good thank for reading
