12 volt ceramic heater questions?
124fan
1997 C250TD auto / 2013 VW Golf 2.0 tdi DSG
I was wondering if anyone had one of these? and if so what do you think of it?
I've looked at a few online and they are not expensive ... so I was thinking they may be a waste of time, if not even dangerous?
Any views appreciated, I did read about them somewhere but could not find it just now.
Cheers
Don't waste your money, Maplins were selling them for £7.50 before christmas, the fan is very feeble for a start & the air that passes through them is only heated by a few degrees.
If you try them in a warm car they feel hot, but use them when it is minus 5 and they only heat the air up to minus 1, so not much point to them really.
Russ
At the price I thought that might be the case. Thanks.
Cheers
If you think about it, a small household fan heater is typically a kilowatt (1000W). To get that on 12V would require almost 85 amps!
As Russ says, anything that small running off the cigarette lighter socket is going to be pretty feeble.
