Morning all this is my first time on the forum as I am at a lose end
I have the Merc Vito 120Cdi Sport 2008 model, this winter (not that its that cold yet) the van is becoming harder to start, it has always started very quickly but now turns over 5-6 maybe 7 times before coming to life, the other morning it started on the 5th attempt (the first 4 times it just turned over then timed out and the 5th time it started). Its done 80k and last serviced in Aug this year, I have read reports saying the fuel filter could be getting block so this was changed yesterday and no difference. I have had the van on a diagnostic and no fault codes were showing, rail pressure is good and no leak off from the injectors. The glow plug module was replaced last winter but I guess there is no way of testing this is ok? The glow plug light illuminates for 3-4 seconds then goes off when first starting the engine so I guess this is normal. I have been told by a merc mechanic that if a plug or the relay was faulty there would be a malfunction on the dash and or the light would remain on. I normally use supermarket fuel and never had a problem with any of the diesel cars I have owned.
Any help ideas would be great.
Thanks Paul
Thanks Paul
