123 Ignition barrell needed ASAP
jaymanek
Nuneaton Warwickshire
Hi All,
I have an 123 that i use for spares and towing caravans around our drive (Long story). Basically the ignition lock was getting fiddly and i thought id just take it out before it completely collapsed. The idea was to get the key part off so i could turn with a screwdriver. However when i tried to do it, the key just wouldnt turn and ended up drilling the steering lock and getting it out that way. Anyway, i have got down to the switch, but its messed up, it just turns the starter without ignition no matter how i turn the switch...
So the long and short
I need an ignition barrell complete with key..(or even a broken one that will start the with a screwdriver) The whole thing so that i can just plug the connector into it and start and move the car once a week or so.
I need this this week if poss, anyone help?? Not sure if 124 is same connection or not...
Cheers
Jay
jaymanek It just turns the starter without ignition no matter how i turn the switch...
I had the same problem with my daughters Fiesta, she had to use a screwdriver for a while. To get the car to fire the key had to be close to the steering column because of a security chip in it. I fixed the key near the transponder with a cable tie while waiting for a new lock.
Do you think your existing key could have a chip in it?
Not on a 123, unless its had a aftermarket security system (quite recent).
No 123's arent that complicated, i think i just got shards of metal in there when drilling. Tried cleaning it but just doing the same thing. No matter what i do, as soon as i connect the batter, starter motor goes, but no ignition.
I will sort you out just the rear switch if you want, so you can use a screwdriver...
yes please V12, i was waiting for you to return from hols!
Cheers
Jay
